Moho Debut 12. I'm building some instructional videos for first year Engineering, and I need to make a counter. As far as I can tell, my only option seems to be a layer for each digit in each position (e.g. 1-20 means 10 frames for the ones digit and 2 frames for the 10's digit and use the layer effects to turn the frames on and off as needed. Is there a better way?
Thanks.
Text Counter
profcodegen
Re: Text Counter
If you need to show exact numbers, responding to some other element in the scene, a switch layer is one good way of doing this. It contains a layer for each number 0 - 9, plus one empty layer if you don't want leading zeros. Build that switch once, then duplicate it for as many digits you need. You can easily create a "running numbers" animation by switching through all numbers and make this a loop, then stop at the desired value.
Another solution would be a number strip within a mask: again 0 - 9, but arranged vertically on one layer, and the mask only showing one number at a time. This allows for an old-fashioned "numbers on a roll) effect, but needs more precision with placing each number.
profcodegen
Re: Text Counter
I haven't gotten to the switch layer in the tutorial yet, so I can look at that. That seems almost exactly
what I need. Thanks for the pointer.
Is there a way to do layer masking in Debut? The tutorial manual seems to suggest that Layer Masking is Moho Pro Only.
Re: Text Counter
Yes, you just have to use bone layers instead of group layers.profcodegen wrote:Is there a way to do layer masking in Debut? The tutorial manual seems to suggest that Layer Masking is Moho Pro Only.
profcodegen
Re: Text Counter
Thanks.
