Hide frames in timeline
grns
Post by grns »
Hello i come from Animate, and things are different in Moho, so i have some trouble to understand how some things works. I really cant find out that:
- How i hide certain frames in timeline?
i dont mean Masking, i just want some things to dissappear for a certain period of time
Re: Hide frames in timeline
the best approach depends on the setup.
> if it's a shape you want to disappear - you could animate its fill / stroke to be totally transparent.
> if it's a whole layer - there's layer opacity and layer visibility
> if it's part of something then you can animate a mask to hide just the part you don't want (yeah - I know you said not masking!)
> you could use a switch layer with the object in one child layer and another child layer that's empty
> you can move the thing out of the camera view
and all those (except layer visibility and switch to empty layer) can make a gradual or step transition from visible to invisible or vv
… and I'm sure there are other approaches
Bottom line: loads of ways - design the setup and chose according to the visual effect you want to achieve (or, if you have the setup - use the one that works best given what you have)
grns
Post by grns »
I dont know what is "switch layer", but i will try to learn, since is the solution to the problem i have.
p.s.
If i understand, In Moho, when you import something in stage, stays visible all the time, without the need of Keyframes?
Yes. All objects exist for the duration of the scene/project file, like in any 3D program.
