Can a script select a layer?
There are four or five layers I need to constantly select (in a project with hundreds), do you know if there's a way to select a layer using a button script in the tool palette?
I'm thinking on this idea:
- Put a "selection1" tag in the layer I want to select
- Have a button in the tool bar which every time I press it, it will select the layer with the "selection1" tag (I could also add a shortcut for it)
Since I have room in my tools palette, I could have several buttons referring to different tags.
Do you think that is possible?
Re: Can a script select a layer?
yes -- there's a script interface command ScriptInterface:SetSelLayer(layer, multiSelect, allowDeselect) -- scan the layers for the required tag and use it!..
e.g.
function hs_sel_by_tag (moho, tag)
		if not tag then return end
		local i = 0
		repeat
			layer = moho.document:LayerByAbsoluteID(i)
			if layer then
				i = i + 1
				if layer:UserTags() == tag  then -- or contains string (e.g. use string.find)  or ..
					moho:SetSelLayer(layer) -- (or for multiselect (layer,true) and no following "break"
					break
				end
			end
		until not layer
		return
end
What I'd do is put the above into a file as utility function i.e. hs_sel_by_tag.lua goes in the utility folder
(that core code has been tested -- but it doesn't look to see if there are multiple layers with the same tag -- many ways to address that -- e.g. multi-select; or flag an error; or start from the last selected and move on rather than always start at 0; or .. depends on what you exactly want)
and the guts of the buttons are
local required_tagname = <whatever>
hs_sel_by_tag (moho, required_tagname)
you could (additionally) have a "general" button that asked the user for the required tag
Stan's new script generator should take the strain out of that!
hope that's helpful.
Not sure if this is exactly what you have in mind, but try this out, Victor: https://sites.google.com/site/synthsin/ ... ects=0&d=1
With this tool selected, if the first layer tag is a single-character (and available as a shortcut in Moho), hitting that key will select that layer.
It's up to the user to make sure the shortcuts they use are available and not duplicated, and uppercase (shift+key) and lowercase are separate shortcuts.
hayasidist wrote:yes -- there's a script interface command ScriptInterface:SetSelLayer(layer, multiSelect, allowDeselect) -- scan the layers for the required tag and use it!
Thank you very much, hayasidist!
This will be very useful for me.
synthsin75 wrote:Not sure if this is exactly what you have in mind, but try this out, Victor: https://sites.google.com/site/synthsin/ ... ects=0&d=1
Wes, this is just fantastic! Thank you very very much! I will start creating all my rigs with this tool in mind!
I've vastly improved this tool.
Same link: https://sites.google.com/site/synthsin/ ... ects=0&d=1
Full description here: viewtopic.php?f=12&t=32641
I was just thinking there should be an easier way to select deeply nested layers, like an editable/clickable list of frequently selected layers or something like that. Then I remembered this thread.
Will give the script a try today. Sounds like it might do what I need. :)
Hopefully it's a bit faster than opening and scrolling through a list of layers.
