Layers names disappeared !
Twisto
Post by Twisto »
Hi
After I save my project and open it again all layers names vanished:
How can I fix it?
Re: Layers names disappeared !
It looks like the column is moved to the right.
Try undocking the window (in the menu Window/Docking/Layers) and check if the column is still there.
Another option I highly recommend is go to the Preferences, Layers/Objects tab and check "Auto-size Name column".
Personally I can't work without that option on.
___
And related to that, I also recommend to uncheck the "Search filter always shows parent..."
At least for me, using the filters makes much more sense without seeing every parent.
And finally -to save space- you can also remove the Label column, since you can also add and see labels by right clicking over the eyes of each layer.
Twisto
Post by Twisto »
Víctor Paredes wrote:It looks like the column is moved to the right.
___
Thank you dear friend! :D
