vector layer icon
Gnaws
vector layer icon
Post by Gnaws »
This layer icon appeared as I was breaking out layers from AI to Moho....
https://ibb.co/Jx4F6cW
What does that mean?
Re: vector layer icon
It means the layer is only composed of triangles, so it's a triangulated layer that can be used as a smart warp mesh.
Gnaws
Post by Gnaws »
synthsin75 wrote:It means the layer is only composed of triangles, so it's a triangulated layer that can be used as a smart warp mesh.
Wow. That was not supposed to happened.
How do you triangulate a layer?
You can triangulate a layer using Draw>Triangulate 2D Mesh, but if a layer just happens to only have filled triangles, Moho will show it as triangulated too. It's no different from a regular vector layer. Just means you could use it as a smart warp mesh. If the icon annoys you, you can just add a little filled square or circle somewhere way outside the camera view.
Gnaws
Post by Gnaws »
Odd that only that layer came out looking like that. I must have accidentally hit the hot key for triangulate...assuming there is one?
Gnaws wrote:Odd that only that layer came out looking like that. I must have accidentally hit the hot key for triangulate...assuming there is one?
No, it probably only has three-point filled shapes. That's all it takes.
There is no default hotkey for triangulate.
Gnaws
Post by Gnaws »
Ooooooh gotcha. That makes sense in regards to this particular vector shape.
Thanks, Wes
