Customize ease keyframes for layer motion
Shizukuishi
Post by Shizukuishi »
I am new to this forum but I'm a long time Moho user. I use After Effects also and, as many users here I wanted to edit the ease parameters of a layer translation, mainly for motion graphics. I had come to a nice trick that's very simple for easing keyframes and I thought that would be very useful. I haven't read it anywhere, so I'm posting it here.
Let's dive in:
If you're an advanced user you should already know that manipulate bezier handles for layer translation could be very tricky, especially when the path is not straight and parallel to the X or Y axes, with curves etc. So what you can do instead is to use the follow path. After you set up your motion path and added keyframes to the follow path channel all you have to do is switch those keyframes to bezier. Done! Now in the motion graph simply adjusting the handles you can ease in or out as you want!
Of course you can add keyframes in between for playing with time and space.
Basically, what you obtain is a sort of acceleration or deceleration graph but for me it's hard to explain physic concepts, so it's better end up here.
Just play around and see the result!
Hope it helps! Have fun!
Even with the head in the clouds You can touch the ground
https://marisolpetretto.myportfolio.com/
https://www.linkedin.com/in/marisolpetretto/
Re: Customize ease keyframes for layer motion
Nice tip. Sounds relevant to this post: viewtopic.php?f=3&p=185943#p185943
Shizukuishi
Thanks Syntsin! I came to to this solution exactly thinking the same. It does the job pretty nicely :D
formxshape
Post by formxshape »
having tried this in the past things can get really messy when you need to then get that object 'off' the 'follow' path and moving again.
formxshape wrote:having tried this in the past things can get really messy when you need to then get that object 'off' the 'follow' path and moving again.
Duplicate the object and swap visibility.
