After creating a vector line width, how can it be changed ?
Say I set line width at 6, now i want to change it to 2.
Line Width Stroke Change
- hayasidist
Re: Line Width Stroke Change
just the one shape? if so: select it with the shape select tool; go to the styles panel and type "2" to replace the "6" in the "width" box.
if it's more that that try this most useful tool by Stan: http://lostmarble.com/forum/viewtopic.php?f=12&t=30071
My Problem is not the line width, It's how to stop the "Random" line width.
Line width tool (W).
Draw>Reset Line Width
- hayasidist
and … are you using freehand? if so, to prevent it happening in the first place, look at the freehand options pop-out menu and pick the line width options you want - maybe "none" and not taper start or end would do what you want?tosiyori wrote:My Problem is not the line width, It's how to stop the "Random" line width.
