1920x1080 in Moho 12.4
zoesan
Post by zoesan »
I usually work at 1280 x 720 and export as image sequence to Blender. I've noticed that some entry requirements for submissions request 1920 x 1080 so set up a file of that size in photoshop and imported into Moho, from the project settings I selected 1920 x 1080 but nothing changed the dimensions on screen, I then imported the file size saved in photoshop, it far exceeds the dimensions on the screen.
Re: 1920x1080 in Moho 12.4
(Why would you need that PS file? Just set Moho's project dimenson to 1920x1080.)
Oh, OK. Bitmap Artwork imported to Moho will be treated as 72dpi at the moment of the import, which means, regarding to the project settings at that time. Set the dimensions in Moho first, then import. It should fit perfectly.
Changing project settings later will not change any dimensions of any already imported bitmaps (which would be the horror!).
zoesan
Post by zoesan »
thought it could be done on the fly, the test file from photoshop set at 1920 x 1080 now fits. Thanks slowtiger.
