Smart Mesh on mixed vector and bitmap?
Re: Smart Mesh on mixed vector and bitmap?
Since fill textures are only influenced by bones, you'll probably need to mask the texture, as an image layer, with the vectors so the smart mesh can control both.
One more thing: This might sound basic but, If you're using an Image Layer with the mesh, be sure you are animating the mesh at frame 1 or later. Frame 0 is for setup and you won't see the texture deforming there by moving points...that only happens from frame 1 forward.
Lychee
Post by Lychee »
hismaimai9999 ????????????! :|
It's strange that on your first post you copy mine instead of continuing the discussion on the original post.
viewtopic.php?f=5&t=29716#p168916
That's weird. Spambot maybe?
Thanks for pointing this out Lychee.
Ah, I'm guessing that signature might become spam links at some point.
