Groups inside Mask-Groups displayed wrong(but render correct
DrNibbert
Post by DrNibbert »
Hey everyone!
Whenever i use Groups (wheather its a Switch-, Masking- or just a normal Group) inside a Masking-Group, it gets displayed wrong in the viewport.
But when i render it out, it is displayed correkt, so i don't think its a mistake i made.
I uploaded an simple example-file, can you verify this bug?
https://www.dropbox.com/s/vftfqvljwjqny ... .moho?dl=0
Especially with more complex rigs this gets quite anoying.
Thanks for your feedback!
(Moho 12.5 on MacOS)
Showreel 2018 https://vimeo.com/254290989 - Moho 12.5.1, macOS 10.10, Adobe CS6
Maestral
Re: Groups inside Mask-Groups displayed wrong(but render cor
Post by Maestral »
1. Do you have GPU acceleration* (un)checked?
2. Why is your mask above the masked layers?
* lower right corner, Display Quality
that file works fine here -- display and render the same - win 10 12.5 (but I always have GPU off!!)
but there is a known issue with complex / nested masking where the situation is exactly as you describe. e.g. using masking to create a mask -- taking your example file -- make group 1 a "hide all" masked group with its layer 1 as add invisibly to mask; and animate the points in the rectangle to partially include the other shapes...
chucky
Post by chucky »
GPU is great for image-based files but masking anything but the most simple file fails horribly.
Don't count on the display for non-gpu display either ( at this point in time) it may be still different if complex.
FWIW, I normally have GPU Acceleration disabled too. As mentioned by Chucky, it often messes up when displaying masking. There are a few situations where enabling GPU acceleration will speed up Moho but, for me, having accurate (or mostly accurate) mask previews is far more important because I tend to use masking A LOT in my rigs.
IMO, Moho is usually fast enough with it disabled anyway.
DrNibbert
Post by DrNibbert »
Thanks for all your replies! You`re right, turning of GPU fixed the problem!
In another of my Rigs the Masking Group is displayed correctly WITH GPU and wrong when GPU is off :lol: Weird.
Guess i'll have to try case by case wich one works best.
Different graphics cards/chip sets and drivers might be the reason for the inconsistencies. The only way to know for sure is to try.
For me, I leave GPU acceleration off until I feel a project's interactivity is getting too slow to work with. Then I switch it on and, if it helps, I leave it on while I'm working in that project. If I see no difference in performance, I turn it off again.
A while back, I was told that the dev team was looking into improving Moho's openGL, so hopefully this means improvements for mask previews too. Just have to wait and see.
