I'm trying to create the body of a snake to rig. So far using a long vector shape with lots of points, the segments set to curves, and "sketch bones" seems to work on a quick draft. But when I go back in to do a precise drawing, I wonder how to add all the points symmetrically. (so for example you had 20 points along each side, all evenly spaced). Am used to vector art in inkscape, where you can click a segment, and add points to your hearts content, but don't see how to do this here (I am using version 11 pro). And when I do the art in inkscape and import as an svg, most of the points are missing.
I could of course eyeball it, but there has to be way to get it precise.
Add Symmetrical Points
Re: Add Symmetrical Points
Menu command Scripts>Draw>Split Curve.
Awesome! Thanks.
