Audio Problem
tosiyori
Audio Problem
Post by tosiyori »
The Audio I have in iTunes has a specific tone, when I play it in MOHO Pro 12 it has a much lower tone. I tried to use the "Audio Level" in Animation, all I can do is make is a lower tone. It won't use the minus sign.
So in essence, how is the audio tone changed in MOHO Pro 12 ?
Re: Audio Problem
Try the menu command Animation>Allow Frame Skipping
The audio pitch is lower because the timeline can't play every frame in real-time, and is playing it slower.
tosiyori
Re: Audio Problem
Post by tosiyori »
Thanks for the advice, it worked out OK.
TobeDowns
Re: Audio Problem
Post by TobeDowns »
Hello..I am additionally having this issue, however I am utilizing AS8 Pro.
The sound is fine while I'm chipping away at the movement, yet when I trade, I get explosions of static after boisterous sounds play. My sound levels are inside typical cutoff points, nothing is fixed. I had a go at bringing down the volume of the clasps, sparing the movement to various organizations lastly got one that was alright, however there is as yet a slight piece of static.
order pcb
