Moho in Linux - question
- Banterfield
Any tips with installing moho in Linux? I have a fresh install of Ubuntu. Should it have by default the required GTK and Glibc packages? When I attempt to run the "moho" script nothing seems to happen. Will the script fail if the font path isn't correct?
I'm a total noob on Linux, so I apologize in advance for my meat-headedness.
Dave
- Banterfield
- Banterfield
Hi Jorgy,
So, I opened a terminal window, went to the moho directory and attempted to run it (hopefully terminal and command line are synonymous).
It said something to the effect of "Bash doesn't recognize command: moho" which to me means it doesn't know it's a script.
I modified the file with a text editor and changed the font directory and entered an explicit directory path for the moho files. Still no joy.
When I attempt to run the script file from the gui, it gives me the options to "run in terminal" "display" "cancel" and "run". Running in terminal brings up a terminal window, but shuts it off before I can read what has transpired. Display opens the file in the text editor. Run doesn't seem to do anything. Any suggestions?
Dave
- Banterfield
For some reason, moho is unable to tell the directory from which you are running it (the 'dirname' error). Using a text editor, put in a line at line 19 that looks like:
MOHO_DIR=/home/bla/bla/bla/moho-dir
where the right hand side is the full path of the directory where moho is installed. Let me know how this goes.
- Banterfield
Argh. Here comes my meat-headed question.
Is the terminal window supposed to recognize "moho" as a script automatically, or do I have to give it a command to execute it as a script? Because it doesn't and I can't figure out how to make it execute.
I'm trying to run it under Mandrake, which I've heard is a more complete installation, and can't figure out how to get it to run the script.
Thanks
Thanks
Dave
- Banterfield
I should mention that under Ubuntu I got an error that said a library resource was missing. Because I couldn't tell if I had GTK 2 (which I think I did have) or glibc (which it appeared I'd have to compile to use) I switched over to my existing installation of Mandrake, on my second drive on my Linux box. .... So I'm not being completely flighty.... not completely...
Dave
- Banterfield
- Banterfield
These are libraries for std c++. On my Fedora Core 4 box, I have these RPMs installed:
You will probably need to have a 4.x version and a 3.3 version installed.
libstdc++-devel-4.0.2-8.fc4
compat-libstdc++-33-3.2.3-47.fc4
libstdc++-4.0.2-8.fc4
- Banterfield
Well, I finally got everything working. I installed both 4.6 and 5.3. I was missing those gcc packages mentioned in the readme. It took some doing, but I eventually I got all the right stuff in place.
So, it looks like the things that were really key to getting installed were:
1.) Getting that "sh" command for the terminal so I could run the scripts
2.) Getting the path right
3.) Having those packages installed, as mentioned in the readme.
Now... what do I install in order to render to a video format? All I can see for options are single frame picture formats. Any recommendations?
By the way, thank you VERY MUCH for being so generous with your time, Jorgy. I've been banging my head against this all evening, and it wouldn't have happened without your assistance.
Dave
Video format on linux? Are you kidding? The only thing that comes close is swf export. What I do is get all of my animating just the way I want it, and then copy it over to a PC running windows for final render into quicktime format, and then convert to mpeg for DVD authoring.
However, this is one alternative: rendering to a series of frames and then turning them directly into mpeg. You will need the mjpegtools RPM. I worked and worked on this, but I was never able to get good quality. I'm sure there is a way since there are so many options to the arguments, but I just got impatient after wasting weeks and weeks.
To convert the frames to video it would be something like:
Let me know if this is the route you want to go - I have some more resources to point you in the right direction. You will also have to mplex in your audio.
So your two basic choices are swf and mpg. What kind of format were you wanting?
png2yuv -f 24 - -j k%04d.png | yuvfps -r 30000:1001 | mpeg2enc -f 8 -o video.m2vSo your two basic choices are swf and mpg. What kind of format were you wanting?
- Banterfield
