smooth joint for several bones
zoesan
Post by zoesan »
I've been looking at tutorials by Moho users and it looks like more Demo's on layer binding than point binding, so I also have begun looking into it, I came across a Video by Victor Paredes titled: Smooth Joint for Several Bones, which looks like a great way, but can't get it to work, followed the Video, but when duplicate layer and select the two bones after using the crop tool, my drop down menu for Create Smooth Joint For Bone Pair is still greyed out.
Re: smooth joint for several bones
In order to work, the Smooth joint for bone pair need to have the bones as straight as possible. If the angle between the two bones is not extended enough, the option will appear greyed.
Here's the original thread, in case anyone else want to check the tutorial :)
viewtopic.php?f=9&t=27158
zoesan
Post by zoesan »
Thanks Victor, like you said when you align bones you get smooth joint as illustrated in your video, will attempt a full body rig based on your very cool findings. May well have to make another post at a later date. Gracias
