Scale Compensation Issue [Solved]
justoshow
Post by justoshow »
Has anyone seen this issue with the layer scale compensation? These two arms are the same. I just copied the body parts (bicep, arm, and hand) with the same setting and same style (uses one line style, skin style throughout the character), but I get different line width with scale compensation upon zooming. Any Ideas?
Thanks in advanced,
Justo
Re: Scale Compensation Issue
Try Edit>Normalize Layer Scale on each layer.
justoshow
Post by justoshow »
synthsin75 wrote:Try Edit>Normalize Layer Scale on each layer.
This worked! Thank you! I only had to normalize the arm with the thicker lines.
