How to change color gradients types of existing objects?
HHGG
Post by HHGG »
I have an object with a radial color gradient.
If I click on "..." (right to "Effekt1" "Farbverlauf", out of window)
I get the "Farbverlauf" (translation: color gradient) window.
But if I change from "Radial" to "Linear":
and click "OK" the color gradient type of my choosen object isn't changed.
It's only changed in the little "Farbverlauf" preview window.
My object has a radial color gradient furthermore.
I have seen that new objects are now created with the
choosen linear color gradient. But I want to change the
color gradient type of my existing object from
"Radial" to "Linear".
So how can I change the color gradient type of an
existing object or isn't it possible?
Re: How to change color gradients types of existing objects?
You need to select the shape, with the Select Shape tool, first.
HHGG
Post by HHGG »
Can you or anybody please say where is the "select shape tool"?
I tried the first two tools in the first line to select my shapes
(select points and transform points):
And I find out if I let the left mouse key pressed my
object gets the new color gradient but if I release
the mouse button the changes are away.
So what can I do to change my object permanently
to the new color gradient?
Is the "select shape tool" in my image and where is it?
Or have I to change MOHO settings to get the "select shape tool"?
first one in the fill (fuellen) group - like a kidney with a pointer arrow.
HHGG
Post by HHGG »
Thank you, now it works.
