... numerically transform multiple layers at once?
mrc
Post by mrc »
Hello everyone,
when I select multiple layers, choose the layer transform tool and then type in some new values in the toolbar these values are only applied to the last selected layer.
Have I overlooked a key combination or something?
Marc
You don't agree with the post above? Click here.
www.tricklabor.com/en
Re: ... numerically transform multiple layers at once?
seems to work ok here (win 10 22203) - although I did get a one-off glitch (that I couldn't reproduce) when trying to scale multiple layers - only one did get scaled. But that hasn't happened again!? The layer transform tool code seems to process selected layers correctly (there are loops that process "all selected layers" where I'd expect them). If you're consistently getting the problem - i.e. only one layer out of many selected being updated - could you upload the file (strip out artwork if / as necessary)?
mrc
Post by mrc »
When I create a couple of vector and bone layers it all works fine.
It does not work, though, when I import elements (rigged characters, PNG backgrounds, SVG files) be it by dragging into the document or going through the menu. Then it's only the last selected that scales.
Marc
yeah - there's something not right ... I just imported the "bigsby" character from the library and tried various ways of selecting the immediate (not expanded) child layers of the main bone layer - and scale does not seem to want to work on all those selected - seems to leave one. More evidence gathering needed, but I think this will end up getting logged as a bug.
mrc
Post by mrc »
Thanks for checking and testing.
Marc
mrc
Post by mrc »
I think I have found some consistency in the behaviour.
* Image layers need to be selected bottom to top for numerical scale input to be applied to all. CTRL-selecting seems possible.
* Bone layers need to be SHIFT-selected bottom to top for numerical scale input to be applied to all.
Otherwise ony a single layer is affected. Yes, probably a bug.
Marc
it's logged! (39744 for those who care about such things)
