heyvern's old hm_switch_commander script
coatsiecoates
Post by coatsiecoates »
Does anyone have a copy of this, or know where to get it?? The link to where he kept it on the Hubu Media page is not valid anymore.
DK
Re: heyvern's old hm_switch_commander script
Post by DK »
You could possibly contact him here. His avatar is still on the front page.
https://www.hubumedia.com/
Cheers
D.K
chucky
Post by chucky »
I found Vern's switch layer bone control script . Would that do it?
coatsiecoates
The script he did that I'm looking for assigns ctrl + 0-9 to each of the phonemes in a mouth switch layer.
I have a ShuttlePRO V2 and want to assign a button to each sound so I can use the scrub wheel and buttons to fly through lip sync.
...that is, unless someone's finally devised a way to completely automate it reliably.
...OR knows of another way of assigning a key command to a switch layer.
Thanks!
jezjones29
Post by jezjones29 »
I don't have the original, only a tweaked version I use. I think this is what you're after. It works with Moho 12.4
https://www.animestudiotutor.com/link/528/
(I have removed a lot of my code to make it as close to the original as possible)
velu
Post by velu »
jezjones29 wrote:I don't have the original, only a tweaked version I use. I think this is what you're after. It works with Moho 12.4
Great script!
Is there same this script for bone layer (lips)?
I love Moho
Monkey Possum
Post by Monkey Possum »
I'm trying to use this script. I have the switch selector set up. The script "Switch Layer Plus 1.1" appears in Scripts / Tools pulldown menu. It is grayed out unless I select the mouth layer, so I select the mouth layer. I choose the script.
What do I do now?
