Move Same ID Points in Different SubVector Switch Layers ¿.?
Rai López
Post by Rai López »
Could be possible a Tool (or tool modification) to Move same ID Points at a time in different sub Vector Layers inside the same Switch Layer? Uf... Well, sometimes work with Switch layers can be a pain cause if you animate a point in one sub Vector Layer and you want maintain the point there, even if you change Switch Layer value/pose, you must animate that point too in the rest of the layers up to the same position at the same time... and well, with a lot of Sub Vector Layers really it can be a nightmare... Well, I think this would be specially usefull to can work with only one Switch Layer and maintain all objects perfectly attached with the influenced of the bones meantime the points are animated... A little difficult to explain, but a very important thing to me... Mmmm, well, hope more people wish it! ...CIAO! :)
