Loop switches in Switchlayer [script]
rylleman
Post by rylleman »
Here's another switch script, similar to my Random Switch script, (forum thread).
Loop Switch Script --Right click to download.
Usage: Select a Switch layer and run the script.
The switches in the layer will then be layed out in the timeline following their layer order.
The parameters you can set is start and end frame in the range, interval between the keyframes,
and you can also select to lay out the keyframes in reverse, starting with the last switch, going downards in the list.
If the switches reaches the last one before the range has reached it's end they will start over from the beginning.
bupaje
Post by bupaje »
Thanks for the cool addition -and the other as I missed it first time around- should be useful. :)
Rai López
Post by Rai López »
YEAH! THANK YOU TOO for my part!I must experiment more with both scripts, but... listen, do you think an addition of a text box to specify which Swith layer you want add randomnly in time? I think could be interesting... BYE!
rylleman
Post by rylleman »
Ramón López wrote:listen, do you think an addition of a text box to specify which Swith layer you want add randomnly in time?
Actually I have thought of that. I just haven't figured out a way to do it...
I'm planning on combining both switch scripts into one and add some other features as well, selecting which layers to include is one of them.
Rai López
Post by Rai López »
...EY, EY, EY,!!! THAT'S SO GREAT!!! :D THANK YOU for add funcionality! I think something like that could be very USEFUL for me actually :), and... yeah! Combine the scripts in only one is always a good idea if possible! GOOD LUCK! :D
ulrik
Post by ulrik »
Thanks Rylleman for your usefull scripts! :D
rylleman
Post by rylleman »
Small update on this script.
You can now also set to use every # image in the sequence.
Setting it to 3 for instance would use images 1,4,7,10 etc.
DK
Post by DK »
Great script!!! Thanks rylleman :)
D.K
paulcopeland
Post by paulcopeland »
Wow what a great little script.
Thank you.
Paul.
Get my free piano sheet music here http://www.scoreexchange.com/profiles/pianoedition
