Hello, I am fairly new to Moho pro and having an issue that I am sure is a simple fix, but I cannot seem to find it! Basically, all of my channels are now 1, before the channels were separate for every action, size change, point change, bone movement, Rotate, ect...
This is how it looks now. I am sure it is just a setting change, but I've searched for hours and just failed. This is really hindering my animation progress as it's a lot harder to redo simple movements.
https://gyazo.com/0fe9f6a86b8e2f441ae5f0ef27280c86
For reference here is some of the past work I've done in moho so far
https://orig00.deviantart.net/a9e2/f/20 ... c1r447.gif
https://orig00.deviantart.net/b07d/f/20 ... c0s8h4.gif
https://orig00.deviantart.net/faac/f/20 ... c1r4ww.gif
How do I get back All Channels?
ameangelofsin
Re: How do I get back All Channels?
Make sure Animation>Consolidate Layer Channels isn't enabled.
If that doesn't work, right-click the channel icon and Un-consolidate.
ameangelofsin
I should have known it was that simple! The first option worked. I've been spending the past few days messing around with settings completely lost!synthsin75 wrote:Make sure Animation>Consolidate Layer Channels isn't enabled.
You're a lifesaver, thank you.
