Quicktime format option not showing on 'export animation'
Rnoir
Post by Rnoir »
I've recently formatted my PC (updated Windows 7 to 10) and installed Moho pro 12 again. The thing is that previous to formatting my PC I was already working on a project animating characters with a transparent background and exporting them in Quicktime format (with the "animation" preset in order to get the alpha channel). I did installed quicktime beforehand too, but still the quicktime option is nowhere to be found. Any idea how to get the quicktime format option back?
Re: Quicktime format option not showing on 'export animation
Rnoir wrote:I've recently formatted my PC (updated Windows 7 to 10) and installed Moho pro 12 again.
after your reformat, did you install and run the 32 bit version of Moho? is the quicktime player installed?
manual page 411: wrote: QuickTime: (Mac and 32-bit version of Moho Pro for Windows only. Not available
in Moho Debut or 64-bit Windows). Saves the movie in QuickTime (mov) format.
On Windows, QuickTime output format only appears in the 32-
bit version of Moho Pro. The 32-bit version of Moho Pro is not
installed by default; you will need to check the option to install
during setup. You will also need to have QuickTime player installed.
jezjones29
Post by jezjones29 »
As hayasidist wrote, 32bit version is probably the answer, but it's not recommended to have Quicktime for Windows installed due to its security vulnerabilities. Apple no longer support it.
I now use PNG images (output > format > image sequence).
Rnoir
Post by Rnoir »
Yep, it was that. I reinstalled moho (this time also the 32bit files) and now it shows. Thanks!
jezjones29 wrote:As hayasidist wrote, 32bit version is probably the answer, but it's not recommended to have Quicktime for Windows installed due to its security vulnerabilities. Apple no longer support it.
You can install only Quicktime Essentials (one of the install options) to get the codecs without the security vulnerabilities of the QT player.
But yeah, PNG sequence is a good option too.
