OpenToonz v1.2 released!
				herbert123
Although called a "minor" update, this version includes:
- a horizontal timeline which is zoomable (!)
- MyPaint bitmap brush engine that expands OT's bitmap painting capabilities far beyond the initial release
- Guided drawing for vector brushes
- flip viewer horizontally and vertically
- export soundtrack only
- new note level type (in addition to regular comments the animator can now insert notes in frames)
- custom command bar panel
- new xsheet/timeline command bar
- all Windows builds can be made portable
- edit values with middle mouse button drag
- Mojo brush set for MyPaint
- touch screen controls
- xsheet header redesign
- couple of new FX
and many bug fixes and smaller/bigger workflow and user interface enhancements.
For a full list and the download: https://github.com/opentoonz/opentoonz/releases
- couple of new FX
- uncle808us
Re: OpenToonz v1.2 released!
Clip studio paint EX bitmap,vector,animation (no tweeting) imports 3D this is an fbx from Poser.
Lighting can be adjusted. poseable.
http://uncle808s.blogspot.com
- uncle808us
Same lil'Guy Poser scene imported from Poser Pro Game Dev 10.0.5.30556 as a poser file.
not as easy to pose.
				herbert123
The Western version of ClipStudio supports direct native export to OpenToonz now as well. I use ClipStudio myself, and it works like a charm: create your animation in CS, export, and import in OT. Very powerful combo.chucky wrote:This is interesting...
Needs translation plugin
https://www.celsys.co.jp/en/topic/20170228
Hey Herbert, does it import the Vectors of clip .clp or only bitmap exports?
						- uncle808us
Sorry for the off topic posts I posted to the wrong thread somehow my post should have gone here viewtopic.php?f=5&t=31634&p=180544#p180544 Sorry
Makes sense, all good
						- InfoCentral
From what I understand CSP lets you work with vectors internally but only exports raster.
						- uncle808us
No import or export vector (sadly).InfoCentral wrote:From what I understand CSP lets you work with vectors internally but only exports raster.
Yes I know that , I use CSP all the time but not opentoonz, I was wondering if Opentoonz opens the clip files ( allowing vector editing) or is opentoonz just a way to better time the CSP exported bitmaps?InfoCentral wrote:From what I understand CSP lets you work with vectors internally but only exports raster.
Seems a lot of handling .
- uncle808us
The only thing I can think of is OT has tweeting so you can add that to CS animation.
I have only started to learn OT( I mean like one day) and I still find myself going back to importing CS as .psd into Anime studio pro 11.For tweeting and animation.
				herbert123
Bitmap. However, when you export your black and white strokes into OpenToonz, it takes literally a minute to convert those strokes to center-line vector strokes with dynamic thickness that look absolutely identical. And are resolution independent and editable in OT.chucky wrote:Hey Herbert, does it import the Vectors of clip .clp or only bitmap exports?
Oh wow, that's great , thanks herbert123 !herbert123 wrote:Bitmap. However, when you export your black and white strokes into OpenToonz, it takes literally a minute to convert those strokes to center-line vector strokes with dynamic thickness that look absolutely identical. And are resolution independent and editable in OT.chucky wrote:Hey Herbert, does it import the Vectors of clip .clp or only bitmap exports?
- uncle808us
How do you get the horizontal time line? I can't find itherbert123 wrote:Although called a "minor" update, this version includes:
- couple of new FX
