Need Help Syncing Mouth with Audio
chiefr_suthrland
Quick question, I'm trying to sync my character's lips with the audio and it seemed easy enough...until I played it back from "Frame 1". As the "mouth" smart bone dials, every mouth shape passed appears on my character's face. So, for example, if I have 16 different mouth shapes assigned to 16 different frames on the "mouth smart bone and I'm trying to mouth the word "shackle". Let's say the "Sh" mouth shape is on "Frame 1" (in smart bone mode with "mouth" selected) & the "ah" mouth shape is on "Frame 16"...I'll go to the general timeline and put "Sh" on "Frame 1" and put "Ah" on "Frame 3", but on "Frame 2" I'll see frames 2-15 ("mouth" smart bone frames) appear speedily. Get what I'm trying to say? I know it sounds a bit confusing.
Last edited by chiefr_suthrland on Sat Dec 23, 2017 5:06 am, edited 1 time in total.
Re: Need Help Syncing Mouth with Audio
Generally speaking, mouths smooth out and approximate the sounds they make.
If you put every letter in too accurately to the actually words it looks weird and chattery.
Also our brains expect to see the mouth move 'before' the sound comes out.
I remember when my twin was editing for Disney he said , as a rule , if the sound was ' too dead on' they/he would slip it one frame later. The little delay would make the sync more natural and the viewer would more easily find it believable.
These are just little tips that might help reduce 'weirdness'.
If you're using a smart bone for lip sync, you'll want to set its keyframe interpolation to step, so you don't see all the intermediate phonemes.
chiefr_suthrland
I set it to "Step"...unfortunately, that did not resolve this issue.synthsin75 wrote:If you're using a smart bone for lip sync, you'll want to set its keyframe interpolation to step, so you don't see all the intermediate phonemes.
So here is the one mouth formation that I actually did set in the timeline. I set it at Frame 85...that's when the dialogue begins. You probably can't tell due to the tiny font in my screenshot, but instead of starting at Frame 85...where I placed it...it actually appears at Frame 69. Why...no clue.
Now, the remaining screenshots are of all the other mouth formations I created appearing as the "mouth" smart bone dials down, as I mentioned before.
The 1st one appears on Frame 14
Frame 23
Frame 32
Frame 42
Frame 54
Again, I'm not sure if you can read the tiny font in my screenshots, but the ONLY frame I applied one of my mouth options to was Frame 85 and even that one didn't appear on the correct frame. Can you notice anything in the provided screenshots that might be causing this?
You're getting smooth interpolation from frame zero.
You need to change the frame zero interpolation to step as well. Interpolation settings effect how things animate after the keyframe.
chiefr_suthrland
But I do have Frame 0 set to "Step"synthsin75 wrote:You're getting smooth interpolation from frame zero.
You didn't in any of the above images, and I can't tell with this one (too small).chiefr_suthrland wrote:But I do have Frame 0 set to "Step"synthsin75 wrote:You're getting smooth interpolation from frame zero.
chiefr_suthrland
Yea. My laptop's being weird. Some screenshots come out big...others come out small. But I have a feeling we're talking about 2 separate things. Because none of the initial screenshots I provided was of Frame 0...& in the screenshots that "weren't" ridiculously small you can clearly see "Step" selected at the bottom left. Are you seeing something that I'm not seeing?synthsin75 wrote:You didn't in any of the above images, and I can't tell with this one (too small).chiefr_suthrland wrote:But I do have Frame 0 set to "Step"synthsin75 wrote:You're getting smooth interpolation from frame zero.
Last edited by chiefr_suthrland on Sat Dec 23, 2017 4:09 pm, edited 1 time in total.
Yes, the selected interpolation doesn't change the interpolation for existing keyframes. So I can see the frame zero keyframes on your timeline are still smooth keyframes. You'll want to right-click those and change them to step.chiefr_suthrland wrote:Are you seeing something that I'm not seeing?
chiefr_suthrland
Okay. So after I changed them from "Smooth" to "Step", I ran into another problem...and another problem after that lol. I got everything working now though...finally! Synth to the rescue again. I'll probably need you or Greenlaw to rescue me again soon, so don't take your cape off just yet lol. Happy holidays, my friend!synthsin75 wrote:Yes, the selected interpolation doesn't change the interpolation for existing keyframes. So I can see the frame zero keyframes on your timeline are still smooth keyframes. You'll want to right-click those and change them to step.
Last edited by chiefr_suthrland on Sat Dec 23, 2017 6:55 pm, edited 1 time in total.
Glad to hear you got it sorted.chiefr_suthrland wrote:Okay. So after I changed them from "Smooth" to "Step", I ran into another problem...and another problem after that lol. I got everything working now though...finally! Synth to the rescue again. I'll probably need you or Greenlaw to rescue me again soon, so don't take your cape of just yet lol. Happy holidays, my friend!synthsin75 wrote:Yes, the selected interpolation doesn't change the interpolation for existing keyframes. So I can see the frame zero keyframes on your timeline are still smooth keyframes. You'll want to right-click those and change them to step.
Aside from holiday celebrations, I'm sure we'll be around for the next issue.
Merry Christmas!
I just saw this thread and only skimmed through it, so apologies if I repeat anything already mentioned.
Some quick tips:
In the SBD action, I make my first keyframe at frame one and set this to linear. Frame one's switch drawing should be the same as frame 0. Then the rest of the action should include all the other drawings in sequence. This way, every drawing gets equal exposure because of the linear interpolation.
Frame 0 for the SBD, as discussed, should be set to Step. This is why I make a keyframe in the Action at frame 1: it's so the Action can have a different interpolation mode (Linear) from the Mainline (Step.)
Now here's a very important tip:
I noticed you set your default interpolation mode to Step. Don't do that. Instead, set it to Copy Previous Key.
If you set this to Step, every new keyframe you create for any item will become Step unless you change it to something else...which will get annoying as heck because you're going to be constantly switching back and forth to something else endlessly.
If you set this to Copy Previous Key, then Moho will use the interpolation mode from frame 0 (or whatever the previous key is.) In this case, the switch layer SBD will only use Step but anything else you animate will use whatever mode you have set for frame 0 (usually Smooth.) This is much easier to work with because you won't need to be concerned about constantly re-setting the default mode.
BTW, Copy Previous Key essentially mimics how keyframing works in After Effects. This what you want most of the time during animation. In fact, I almost never change it to anything else. IMO, this should be the default mode for Moho after you first install it.
Hope this helps. Good luck!
Some quick tips:
I agree. I ALWAYS leave mine set to Copy Previous Key.
chiefr_suthrland
Thanks, man. You're definitely the most helpful dude on this site...you & Synth. I didn't set it to Step btw. Synth recommended that to fix the issue I was having...& it workedGreenlaw wrote:Hi,
Some quick tips:
SBD is smart bone dial...using a smart bone as a control rather than a part of a skeleton.
Copy Previous should be at the very bottom of the default interpolation list.
