Which points are "in" this keyframe?
- hayasidist
I don't like using "auto freeze" (for a variety of reasons -- such as having unnecessary intermediate keys breaks smooth interpolation between actual endpoints!) but I had an issue with keeping track of which points I'd moved especially in smart mesh - after pulling and poking points around I had no idea what was keyed when... so I made a tool for that ... http://www.mediafire.com/file/yidx32gvf ... tKeyed.zip which I've now updated to do the same for bones and I'm letting it loose into the wider community! Select a key in the timeline; run the tool: the keyed things are selected, the others aren't. Take a look at the readme for more.
Installation - copy the .lua and .png into your custom tools directory.
comments / bug reports / ... all welcomed
Edit: link updated!
Edit: link updated!
Re: Which points are "in" this keyframe?
I got this when trying to download:
"Invalid or Deleted File.
The key you provided for file access was invalid. This is usually caused because the file is no longer
stored on MediaFire. This occurs when the file is removed by the originating user or MediaFire.
Still have questions, or think we've made a mistake? Please contact support for further assistance"
- hayasidist
Thanks John. Sorted the issue - which was that I copied and pasted from a different post -- and where you see the "..." in the middle of the URL - well, that's what gets copied (not the actual "missing" bits of the URL) - updated the link above and for completeness here it is again: http://www.mediafire.com/file/yidx32gvf ... tKeyed.zipjahnocli wrote:I got this when trying to download:
Thanks Paul -- got it. Got no plans for using it immediately, but being a bit of a pack rat, I've got it safely stored if I need it in the future! Thanks for sharing.
- hayasidist
updated this to cater for bones in switch layers. Still in the same place http://www.mediafire.com/file/yidx32gvf ... tKeyed.zip but is now version 1.01
This could be really useful, thanks for sharing!
Hey! Just wanted to say thanks for the script, it's awesome. Should be a built in feature.
- uncle808us
OSX El Capitan Ver 10.11.6
Anime Studio Pro Ver.11.2.1
I have downloaded the file "HS_SelectKeyed" but have no idea how to install,
I tried install script but don't understand the instructions there in.
Also in this thread the following was stated:
"Installation - copy the .lua and .png into your custom tools directory."
I can not find the "custom tools directory"
Would someone please help me out with some instruction?
I appreciate it Thank you.
http://uncle808s.blogspot.com
- hayasidist
This works for Windows / Moho 12.5 -- I'll hope it works for your set up..
start Moho / AS
near the bottom of the File menu is "Open Custom content folder"
in that folder is a scripts subfolder; and in that is a tool subfolder.
copy the .lua and .png into that and restart Moho
hope that helps
start Moho / AS
hope that helps
- uncle808us
Did that but the tool did not show up in the script menu.start Moho / AS
Where do I look for the tool? Thanks
If you are doing everything right, maybe the script doesn't work on your Moho version as hayasidist stated. To be sure that you are doing everything right, check this magnificent Mult Rush video about installing scripts in Moho: https://www.youtube.com/watch?v=TUw1dhpBNEs&t=196suncle808us wrote: ↑Mon Oct 21, 2019 8:24 amDid that but the tool did not show up in the script menu.start Moho / AS
- uncle808us
Wow good help but I got winded just listening and reading.Mult Rush video about installing scripts in Moho: https://www.youtube.com/watch?v=TUw1dhpBNEs&t=196s
Thanks for the help.
- hayasidist
just revisited the tool -- it won't run on 11 or earlier (it needs routines new to 12?)
sorry!
sorry!
- uncle808us
Well that solves that. Thanks
