Animation --> Stop Dynamics Simulation
Rai López
Post by Rai López »
Could be?? I Mean, a Menu option to can active or deactive Dynamics simulation? Normaly there is no problem with this, but if you animate bones or layers in first place and then try to animate or adjust points position, the Dynamics reacts sometimes in a strange/mad way when you go from one frame to another causing that you can't work propertly with the points position... And well, the Menu option seemed to me like an easy and practice solution :) ...CIAO!
Rai López
Post by Rai López »
...BTW! Some time ago I discovered the way to avoid the problem :)
Tip of the Day: " Did you know that if you make Double Click instead only One Click over Time Ruler when you want situate the Current Frame Cursor in the frame position you want, Dynamics are not calculated and your real bone positions are totally respected?" :)
Very quick & easy feature to make work more confortable and eficient so... :arrow: THANK YOU LM!!! To incorporate it even before it was requested! :D
