smart action setup makes character jump across screen
cynthia
Post by cynthia »
Has anyone come across the problem when rigging a character in Moho Pro 12.2? It's been plaguing me through an entire project. I select a leg or arm bone, clink on the new vector action, then the figure jumps across the screen and gets all scrambled. Please see the 2 screenshots. Any ideas on how to fix this would be greatly appreciated.
https://photos.google.com/photo/AF1QipO ... JP0sEqc5ge
https://photos.google.com/search/_tra_/ ... ls2KeoAv2h
NicoGZ
Re: smart action setup makes character jump across screen
Post by NicoGZ »
Hi, it appears that the links you provided don't work.Are you working on frame 0 when you try to create a new vector?
cynthia
Post by cynthia »
NicoGZ wrote:Hi, it appears that the links you provided don't work.Are you working on frame 0 when you try to create a new vector?
sorry the links didn't work for you. I tested them and they work from this end. Thanks for your suggestion --I was on frame 0. I think it might be a corrupt file and/or my inexpert rigging. I'm doing a workaround of rigging each character in its own moho file, then importing the character into the main file as a moho object, thanks to a suggestion by Erik Niells in the Moho Character animation facebook group.
