Hello,
Anyone here in the forum are able to import svg into moho pro 12, even with the latest update, and working perfect?
Because this is seeming to me a thing far beyond reality.
It seems impossible ... Or is something not improved in the update?
AI or Ikscape ".SVG" terrible import in Moho 12
jcdorlando
Re: AI or Ikscape ".SVG" terrible import in Moho 12
I'm getting flawless SVG imports, colors and points and curves. There are things to know about SVG. One, your colors will shift if you start in CMYK instead of RGB. Two, SVG will not record special features like masks or specialty brushes. They may continue to work in the original program but in an export they get lost or changed. What issues are you experiencing?
- hayasidist
I have some svg files that won't import the paths correctly. This issue was logged 18 months ago and is still awaiting resolution. If you can post examples of the problem file(s) I'm sure that will help the dev team.
