condensing keyframes?
cabbage0896
Post by cabbage0896 »
Just a simple question this time, what is the method to condense keyframes? I saw it on a youtube video and I can't re-find it. It was a way of condensing (or expanding) keyframes in the timeline by selecting a group of keyframes and moving them as a group to speed up or slow down parts of your animation. Anyone? 10Q
Re: condensing keyframes?
There are two ways:
- You can consolidate the channels for every layer of the document by going to Animation -> Consolidate Layer Channels
- You can consolidate the keyframes of a single layer by right clicking over any channel icon and select Consolidate Layer Channels
Personally, I prefer to use the first option (and assign a shortcut to it), because this two options are not totally compatible. If you Consolidate/Un-consolidate the channels using the menu, the layers you consolidated independently will continue being consolidated... I hope that makes sense.
Sounds like you might be talking about alt-dragging a group of selected keyframes to change their timing.
synthsin75 wrote:Sounds like you might be talking about alt-dragging a group of selected keyframes to change their timing.
You are totally right. It seems to be my reading comprehension is not too good today :)
.. like Wes said ... alt-drag ..
you need to have keys in at least 3 different frames in the timeline selected -- the ones you drag and all the ones in between (= none if you only select keys at 1 or 2 different frames in the timeline) move and the ones furthest away from the ones you drag stay put.
cabbage0896
Thank you all for the quick response. Alt - drag is what I was looking for thanks!
