Need Help with Dealing with Bending Limbs
chiefr_suthrland
Post by chiefr_suthrland »
Hey guys, I've made a few characters so far and I'm currently trying to animate their movements, but I'm having a bit of a problem. I set up the arms/legs pretty decent...or so I thought. I made an upper/lower leg and did the same with the arms. I used the hide edge tool so you can't tell, don't want a visible stroke line randomly seen across my characters knees/elbows. I even made sure to round off the lower legs and arms so that when the limb bends it looks a bit more natural. But I guess I didn't do a good enough job in that department. Whenever I adjust the arms/legs in a walking motion it looks awful. Not to mention the fact that you can see the strokes disappear on the knees/elbows when I bend them in a walking motion since I had to use the hide edge tool to remove the strokes where the upper/lower limbs meet. How do I fix this? I know it's possible...I just don't know how.
Re: Need Help with Dealing with Bending Limbs
Without any images or files, it's anyone's guess.
Here are some general guesses:
1. Simple setup: when I'm using segmented art, I usually create a layer with circle the size of the joint with a smaller circled scaled down to the center as a guide for the region between the upper and lower limbs. The outer circle gives me a guide for making the ends match during the bend, and the center point gives you a reference for where the bones should connect. If I do this carefully, I can get nice bending joints in my puppet.
2. Intermediate: Moho has a neat feature called Smooth Joint. Just select the two bones you want to use for the joint and apply Smooth Joint. IMO, this works better with bitmap images--in fact, it works surprisingly well for many situations with bitmap art.
3. Advanced: Use Smart Bones. if you're using a single drawing for the limb, make sure your points are distributed for nice deformations. A Smart Bone Action can be used to correct any bad deformations.
4. Really advanced: Lately, I've been creating more vector-based rigs than bitmap, and relying more on Point Binding than Flexi-binding. It really depends on the designs for the character and what they need to do. These days, a combination of Point Binding and Flexi-binding has been working out best in the shows I'm working on. Also, I'm using a technique I learned from Victor, where an 'elbow' or 'knee' bone can be used to help hold the volume of the joint when it bends. Basically, this is a short bone attached the the upper limb, and using Angle Control Bone pointed to the lower limb and set to 50% of the rotation. If you point bind the knee or elbow points on either side of the limb, the small bone will maintain the 'thickness' of that joint. I think Victor's Rubber Hose tutorial illustrates this 'joint holding' technique. For more complicated designs, I may still use a Smart Bone Action on top of this trick to get the exact deformation I need. Typically, the Action will make the inner point of the joint a Peak during the bend, and smooth it out again when the limb extends.
