...create diagonal lines that rotate with the object?
Syd
Post by Syd »
Hello
So, I have several objects that I would like to have filled with diagonal lines. I tried making a style that hade ridiculously long 'spot'-effects, which was okay. But, when I rotate the objects that have the line-style applied, the lines stays in the angle I defined when I created the style.
Is there any other way to get the lines than drawing them with the add point tool? Ideas?
Perhaps it just looks hot?
/Syd
myles
Post by myles »
Image textures? See Tutorial 4.4
Regards, Myles.
-- Groucho Marx
Syd
Post by Syd »
Yes, that would be a way to do it. A bit troublesome since the objects are transforming from small sized to huge when rotating.
Thanks!
/Syd
Rai López
Post by Rai López »
Another problem could be treat to animate points instad bones, or treate to mix the two technics... simply it doesn't works :)
myles
Post by myles »
Hello Syd,
I've made up a little blending script that might help.
http://www.lostmarble.com/forum/viewtopic.php?t=3171
You can create a set of stripes or lines fairly quickly, then mask them with your main shape, then rotate both the lines layer and the shape/mask layer together.
Regards, Myles.
-- Groucho Marx
Syd
Post by Syd »
Very nice!
Thank you!
