Style colour -- Keyframe on timeline channel is invisible
Raaskot
Post by Raaskot »
I give up! Can anyone tell what happens between frame 90 and 91? The boxes (styled) change colour from blue to black and I simply cannot figure out why: Keyframe on timeline channel is invisible. Tried menu Timelines Channel, no result. Can anyone please help?
The moho file is here:
http://raaskot.dk/raalab/animestudio/co ... 1.moho.zip
Kind regards,
Mikael
Re: Style colour -- Keyframe on timeline channel is invisibl
select the layer tekst_baggrund_mellem -- the fill change keyframe is there...
Raaskot
Post by Raaskot »
You're right! I tried clicking the actual switch layers all time (hoping for an alternative result;)) expecting the fill channel to show up, while -- as you write --- additionaly chosing the style in the style drop down menu too makes the point. Thanks alot for the clearification!
Kindly, Mikael
argh -- for the benefit of other readers later -- I accidentally edited out the bit about select the style in the advanced style window when I added the bit about selecting the layer... :oops:
Raaskot
Post by Raaskot »
No worries -- you solved my problem and vaporized my temporary distress :)
