I'm trying to make a ferris wheel rotate. All of the points are on same layer, and then i choose rotate points; however, when i play it back the image seems to zoom in and out. Any advice?
damion
Ferris Wheel
Expanding on gavi dvan's reply:
I think you'll see more consistent results if you assign the ferris wheel to a bone and rotate the bone, or set the ferris wheel layer origin to the axis of the ferris wheel and use layer rotation.
What I suspect you are seeing:
Although the Rotate Points tool allows you to rotate the points while editing, during rendering the points move in a linear fashion from one keyframe to the next. This gives the appearance of shrinking and expanding (the zoom effect you are seeing, I suspect), because the points "cut the corners" of the rotation.
For example: The points in this hand have been rotated with the rotate points tool, but as you can see the points move linearly, leading to the shrink/expand effect.
Solution: Rotate Points is a frame 0 "modeling" tool (or drawing tool). Use bone or layer rotation for animated rotation.
Regards, Myles.
Regards, Myles.
-- Groucho Marx
-- Groucho Marx
