Anime Studio File constant crash!! Lost work!
uncle808us
Post by uncle808us »
I have an Anime studio 11 pro file that I did a lot of animation for. Then I imported a Poser figure posed it etc. saved it.Closed Anime Studio Pro Ver.11.2.1.
Opened Poser Pro Game Dev 10.0.5.30556 opened the file I imported to Anime Studio did some changes saved it (same name) then attempted to Open the Anime Studio saved file :oops: CRASH over and over. All work gone! Arrrgggg!!! Any help....Can't believe I lost all that work.(Hours and hours). :oops:
http://uncle808s.blogspot.com
Re: Anime Studio File constant crash!! Lost work!
Poser Pro Game Dev may have features not supported in ASP11, so AS doesn't know how to handle them.
If you want to PM me a link to the file, I could see about removing the Poser import...and see if that lets you salvage the rest of the work.
Overall, I'd be careful what Poser version an AS version is compatible with.
For anyone else who might run into a similar problem...
It turned out the Poser imports weren't compatible. Simply moving or renaming the imported files will prompt AS to ask if you want to locate them. Denying this request will open the file, although you'll need to reimport compatible files.
uncle808us
I'm not completely sure about the ( Poser Pro Game Dev 10.0.5.30556 ) Import not being compatible.I tried it again and it worked fine
and the problem was not making changes to the figure in Poser. I just did that and Anime Studio opened and reloaded the file with no problem.
So my conclusion is 1. A glitch 2. Operator error. 3. unknown.
But I do want to thank synthsin75 for solving the problem. Thank goodness for the internet and this forum. I could have never found this answer in the Brick and Mortar library years ago. :)
