HSV Modifiers
HSV Modifiers
I've started using HSV Modifiers supplied in extras, on a background, and wanted to animated over time the background, HSV Modifier png, doesn't animate, any way to solve, would make for a cloudy effect background.
- hayasidist
Re: HSV Modifiers
the HSV modifier images are somewhat "old" -- you now have layer blend modes that will give you what you want in combination with vector shapes / strokes / effects. more on blend modes here: http://www.kelleytown.com/forum/animato ... IC_ID=1508 (from AS8 days)
Re: HSV Modifiers
Thanks Hayasidist, what I've found is that if you load the HSV through the Styles palette, instead of the Layers Palette as texture, it then animates and resembles with some adjusting passing clouds.
