Lock and Solo Layer
Brick_Loko
Lock and Solo Layer
Post by Brick_Loko »
not remember seeing those functions in Moho, but it will be helpful to be able to solo and lock vector layers when I'm drawing.
Best
Re: Lock and Solo Layer
You can't natively lock a layer. This is a much re-quested feature. However, Synthsin75 has written a menu script that will do that. Go here for more info: viewtopic.php?p=167236#p167236
Currently there is not a specific 'Solo' option. However, you can easily set this up using the Layer Comps panel. Just set up a layer comp for the currently visible layers, save that as a 'master' layer comp; and then setup another layer comp of only the layer you wish to 'solo'. Using the panel's visibility option, toggle between the two layer comps.
Another option is to simply Alt-Click a layer. This hides all other layers but the one you clicked on. Alt-Click that layer again and it reveals the hidden layers. It a lot like the command in Photoshop, so it has some of same pitfalls. But if you're switching back and forth only between these two views, it's perfectly fine.
