Color Gradient Tool
dkwroot
Color Gradient Tool
Post by dkwroot »
DESCRIPTION:
The color gradient tool will automatically setup the color points between two selected point such that a smooth color gradient is created.
HOW TO USE:
Set the point color of two vector points using the point color tool. Select ONLY the two vector points you want to create a gradient from. Use the script.
HOW TO INSTALL:
Unzip the tools to your custom content folder. Specifically, place them in the tools folder \Moho Pro\scripts\tool
DOWNLOAD: n/a
Re: Color Gradient Tool
Just downloaded it -- thanks!
chucky
Post by chucky »
Another awesome script Thanks!
F.M.
Post by F.M. »
Thank you very much for sharing!
"and then Man created god!"
That's wonderful! I avoided coloring points because it could get tedious but your latest tool opens some interesting doors for me.
Thanks for creating this script and making it available, DKWRoot. I can't wait to try it. :D
malcolm
Post by malcolm »
Hello,
Is there a fade the gradient on a line from 0% opacity to 100%?
malcolm
Post by malcolm »
Is there a way, I meant to say.
chucky
Post by chucky »
check the box in the gradient settings marked transparency. Check the render. Keep display settings 'shape effects' on ( can't remember if it displays though).
malcolm
Post by malcolm »
Thanks! That works.
