im mad!!!
sacrejacques
im mad!!!
Post by sacrejacques »
I rendered an image background and saved it (so it would export faster).
I imported it, and it just wasn't there. The image didn't show, even though it had a whole layer and all. It wasn't blank, but it was invisible. I messed with layer visibility and stuff. Then I unistalled and reinstalled moho. Is the program having a bug or did I do something wrong?
:evil:
Rhoel
Post by Rhoel »
I cannot re-create this error.
I vectored a background, rendered it using cnrt-l + R. Saved as PNG.
Brought it back in as an image layer and it worked fine.
What format did you save you're in?
I also did this for an image. The only thing I noted when the image came back in it didn't fit the camera window. I openned the properties, and selected immune from camera moves and it scaled to fit perfectly.
It could be that the image is there but you are looking at a white/light area. If you scale it down or use the "immune from camera moves"setting, you might see it. Just a thought.
Rhoel
myles
Post by myles »
You might be running into this recently reported bug, which happens in some cases (but not all - like Rhoel, I haven't seen it yet myself).
Now that Lost Marble knows about it, I assume it will be fixed in the next update.
Regards, Myles.
-- Groucho Marx
