I have to animate a big (in terms of resolution) background to export it in After effects and using the camera movement there.
Pratically the background resolution is 3578x500 and I have to animate a lot of things that are out of the windows camera screen.
Can I export the entire animation without using the MOHO camera movement?
Export animation "out of screen"
- hayasidist
Re: Export animation "out of screen"
in moho (file / project settings) set your project resolution to 3578x500 (certainly works in Moho 12 Pro - but if you're on Debut or earlier versions I don't know if you can do this) What export format will you use? This might present another limitation.
I export in mp4 (h264) but I could use another format if it worked.
** Oops.. I just tried and it works! I have arleady changed the resolution in project settings but I don't know why it didn't change anything. Now I tried again and it works.
Thanks.
Thanks.
