Don't know if anyone else has a need for this, but I just wrote a "Rename Styles" script. It brings up a dialog where you can enter a search string and a replacement string. It then runs through all styles and replaces the search string with the replacement string.
I created it, because I like to have my styles named for my characters, so that, if I include multiple characters in the same scene, it's easy to see which style is associated with which character. So, when I create a new character, I can quickly rename styles to match that character.
The script is at
http://www.mediafire.com/file/fk6u2hc5e ... Styles.lua
if anyone would find it useful.
Reame Styles
- strider2000
Re: Reame Styles
I can definitely find a use for this -- thanks!
- strider2000
Re: Reame Styles
Oops, I just realized, that the script uses a utility file, msDialog to make it easy to create dialogs. That script is here
http://www.mediafire.com/file/tvozu9zv7 ... Dialog.lua
I also just added a rename layers script as well, here:
viewtopic.php?f=12&t=30937
Re: Reame Styles
Thanks for both of these scripts - the rename styles in particular will come in handy! And thanks for posting the utility file - I couldn't figure out why it wasn't working before and just knew that it was something I was doing wrong!!!
Re: Reame Styles
I needed this! Thank you for creating it. It'll give me a chance to start learning Moho Lua scripting as well.
