Hello, can anyone assist me on how to export png sequence files and audio, because whenever i finished lip-sync in anime studio and render it out in png format without the audio and i take to my after effects, the audio does not correspond with the lip-sync anymore.
the png file become shorter than the audio file making the mouth not corresponding with the audio
Vector Audio
Re: Vector Audio
Sounds like you have different frame rates in Moho and AE.
Re: Vector Audio
it's 24fps for both AS and AE
- hayasidist
Re: Vector Audio
You might want to check what AE thinks the input footage frame rate is - and if AE doesn't think it's getting a 24fps input feed you can set that using "interpret footage".
Re: Vector Audio
you are right, after checking AE 29.97fps while AS 24fps, i will fix that up and get back here
- hayasidist
Re: Vector Audio
should just need to use "interpret footage" - but in the worst case re-import the AS generated png sequence and tell AE at import time it's (maybe set default frame rate for imported image sequence to) 24 fps.
