some layers and shapes lost in final movie
val56
Post by val56 »
Hello!
I have animated a simple 10 seconds project in Anime Studio 9.5. Just a human head speaking some words .. In the final movie some layers and shapes were lost.
It seems, it's about some settings?
Help me please!
Re: some layers and shapes lost in final movie
? layer settings - "don't render this layer"?
val56
Post by val56 »
hayasidist wrote:? layer settings - "don't render this layer"?
Hi!
No, it seems, I did not marked a layer with "don't render this layer" mark.
This is link to the project file, screenshot and the video with some lost layers and shapes
https://cloud.mail.ru/public/AhHv/LnDnJre9V
Maybe, this helps.
ok. Go to the layers hair-prof and demid-head. Open the "advanced" style panel. Select the shapes one by one and clear the effects you don't want (e.g. in hair-prof the shape has "crayon" effect for fill and "shaded" effect for stroke -- if you don't want these - set them to plain or adjust the parameters).
hth
val56
Post by val56 »
Thank you very much!
Your advice let me to resolve the problem.
But, does it mean that using any style effect may lead to similar problems? Or Crayon is an exclusion?
Do you know any rule that allows applying effects to shapes?
it's all about the parameters you choose... for example: in the hair layer with "crayon" effect -- if you set line width 5 and density .98 you get something reasonable... but if that's not the effect you want you need to change the style or the numbers....
val56
Post by val56 »
Thanx!
I must learn different setting better.
Best regards!
weberr
Post by weberr »
I also want to learn layer settings don't know much about them.
