Motion Graph shows no entires
Gaston
Post by Gaston »
Hey,
I've animated a rectangle from left to right and I want to smooth the end keyframe.
But when I'm changing to the Motion Graph there are no kurves. Why?
dueyftw
Re: Motion Graph shows no entires
Post by dueyftw »
Point or layer motion?
Try layer motion.
Dale
Gaston
Post by Gaston »
It's point animation. But I need point animation if I'll animate a character. Then it must also work with the Motion graph.
So, how can I edit the Bezier curves of my keyframes?
Thanks for any tip.
gjordan
Post by gjordan »
As I recall you need to change to the motion graph then double clic the translation channel, select all the point you wish to control and over one of the selected keyframes, rigth clic, from the pop up menu, select bezier.
Here is a video about a bouncing ball but also show how to use the Mothion Graph, its not mine is from my friend Eric Nielss but its very specific, good luck
My Youtube Channel / Animaciones y tutoriales
https://www.youtube.com/c/JordansDen
https://www.facebook.com/groups/mohocharacteranimators/ Moho Animators Facebook(English)
https://www.facebook.com/groups/mohoproesp/ Moho Pro Facebook(Español)
dueyftw
Post by dueyftw »
I don't use the curves much. I did two test files. One shows them for point motion. One doesn't. Now I'm confused.
Dale
The graph mode shows the translation of single points. Select the point you want and then double click the channel in the Graph Mode.
If you want to control all the point at once, one of the ways is to right click the keyframe and select the interpolation method you want.
