I cannot get bounce and elastic interpolation to work. Eventually I've tried a new project and same issue. Sorry for basic question.
MOHO 11.2.1 OS 10.11.6 Thanks for any help! This is what I do.
Bounce interpolation
Re: Bounce interpolation
Interpolation happens after the key, not before.
Thank you! I guess my playing back and forth was confusing. I did another video. Please take a look.synthsin75 wrote:Interpolation happens after the key, not before.
As you see when I choose bounce or elastic interpolation nothing really changes...
Also the waveform should reflect those interpolation in the motion graph but nothing really changes there as well
I appreciate any help
Now you're trying to do bounce/elastic interpolation between keys with the same value, indicated by the flat line between them in the motion graph. Keys need some change in value to modulate the interpolation over.
The only interpolation that will change anything between two keys that have the same value is noisy.
synthsin75 wrote:Now you're trying to do bounce/elastic interpolation between keys with the same value, indicated by the flat line between them in the motion graph. Keys need some change in value to modulate the interpolation over.
ok, I think I got it. Thanks!
