How do I add phonemes?  "ST" "TH" etc.
I know it's possible to do this, but I don't know how.  Anyone know?
						Adding extra phonemes....
				Lurker
				Dell Boy
Adding Phonemes
Just type in the new Phonemes in the "Break down the word" dialog. There are buttons there for adding the regular phonemes, but you can just type anything.
I suppose you could build your own dictionary, but that's real work.
I'm using new phonemes to add grimaces and protruding tongues etc.
If you want to see it in the animated preview you also have to add a 200 x 200 pixel JPG to the set you are using, showing the correct mouth shape, with the correct phoneme filename, and restart Papagayo.
The output DAT file will contain the names of your new phonemes as you typed them. I'm using Papagayo without Moho (I built a data-driven puppet in Flash) so I don't know how it would work in Moho.
