Greetings Moho forum!
Perhaps someone can help with this.
I attempted to create and apply a style to a group of objects that are copies of one another. These objects are nothing more than circles with halo fill. When I created a style and applied them to the circles they did not take on the new style regardless if the override option on "Fill" was enabled. I also turned the circles into named shapes but still no change. The only way I was able to change the fill color was to manually change each fill color. Each circle is in its own layer.
Thanks in advance,
Ken
Apply Styles to objects after they are created,AS 10.2 Pro
Ken Nichols
Re: Apply Styles to objects after they are created,AS 10.2 P
Might have to post the file Ken?
If you can manually change them then it sounds like you have the default style overrides enabled, which overrides the applied style. What you probably need to check is whether the saved style has its overrides enabled when editing the style. If that's not the problem, I'd probably have to see the file (feel free to PM a link if it can't be shared publicly, or just delete everything but a problem shape for us to troubleshoot).
