I've got two characters built but one unfortunately got a little bigger than i wanted. So now i want to scale him down by layer scaling but then of course, the scaling will be set to 0.5 or whatever. Is there a way to freeze the scaling or apply it like in a 3D software so the scaling will be kept but the values will be reset at 1? Thanks!
Is there a way to apply scaling to layers?
Hi there!
- hayasidist
Re: Is there a way to apply scaling to layers?
If you have scaled down on frame 0 then on frame 1 press reset - that will add a key for the frame 0 value - now go back to frame 0 and press reset and that will set it to back 1 on frame 0 (and leave the smaller value as a key on frame 1.
