Preview settings, where to change them?
Locked
rafdesign
Post by rafdesign »
where can I change the quality, codec and size of the preview rendering?
I don't mind if it takes longer.
Rai López
Post by Rai López »
If you are reffering to the F5 function Preview, you can't (and I neither :()
gavi dvan
Post by gavi dvan »
Ramón López wrote:If you are reffering to the F5 function Preview, you can't (and I neither :()
Ramon loves his F5 function!!
This is a block of text that can be added to posts you make.
There is a 255 character limit
rafdesign
Post by rafdesign »
yes I mean F5. I wonder why is it not possible to change, are you guys sure? It sounds so dumb if it's not possible.
framedog
Post by framedog »
s it me or is this not mentioned in manual..i really like this feature cant work why you cant change its settings was it an afterthought in development?..
sorry if the question is a bit ignorant ive not been using moho that long
7feet
Post by 7feet »
This from the original announcement of the feature:
Preview rendering: press the F5 key to render out a quick preview of the current animation. You don't get to choose any quality options here - it's just a low-quality, fixed codec (QuickTime Sorenson) output, rendered at half the project's final dimensions. This was a last-minute feature addition, so we may add a way in the future for you to specify what kind of rendering options you want to use. The purpose of this feature is to let you see the animation playing back at full speed, even if it's too complex to play back in Moho itself. You could always export the movie yourself, but this feature lets you skip the process of choosing rendering options and codecs, and figuring out where to save the movie file. Just press F5 and let Moho take care of it.
rafdesign
Post by rafdesign »
thanks for the final answer. Hopefully in the future we will be able to overpass those limitations. Remind me Cosa 1.0...
Locked
