Change Image Resolution Script
WHAT THIS SCRIPT DOES:
I created two menu scripts, "image up" and "image down". When you activate "Image Up" from the scripts menu, the script will go through every layer in your document and replace images with higher resolution versions. When you use "Image down", the script will go through every layer and replace images with lower resolution versions.
WHY IS THIS USEFUL?
When creating complex rigs, you will often find that Moho will struggle and even crash when there are too many high resolution images. It is much easier and faster to use low resolution images for animating and then swap those low resolution images to high resolution ones for the rendering process. These scripts make it easy to do that.
HOW DO I SET THIS UP?
It is very simple to set this up. All you have to do is keep two copies of each image you want to work with in the same folder location. One copy will be a smaller version of the other. Just make certain that the file names of the two images are the same, except the large copy will have (large) in its name and the smaller copy will have (small) in its name.
EXAMPLE: Face_(large).png , Face_(small).png
HOW DO I INSTALL?
Locate your custom content folder. If you don't know where it is, just open Moho and go to edit>preferences. Under the general tab, you should your custom content file location. Go into that folder and navigate to: Moho Pro>scripts>menu
Finally, unzip the scripts provided into the menu folder and you're done.
DOWNLOAD LINK: n/a
WHY IS THIS USEFUL?
HOW DO I INSTALL?
DOWNLOAD LINK: n/a
Re: Change Image Resolution Script
I created two companion scripts. These scripts will go through your document and swap out (large) and (small) in your layer names. This is useful for those that want to build characters in moho and export them to a psd file to be edited and exported back to moho.
My method:
- First design your character in Moho. Don't place any layers into groups! Just work with vectors only.
- Make sure all of your layers have (large) somewhere in their name.
- In file>Project Settings make your render size very large. This is going to be the largest you expect to ever zoom in on your character, so make the resolution as large as you think you might need.
- Export your character to an image sequence. Set the file type to "psd" and export only from frame 1 to frame 1. This will give 1 psd file with all of your files rendered out.
- Open your psd file in Photoshop and edit your art however you want. Feel free to add new layers, just make sure (large) is in their name.
- From file>scripts export a moho file. If you don't have the moho export script, you can find it in your custom content folder: Moho Pro>Extra Files the file is named "Export Layers to Moho". Place this file inside of photoshop \Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Presets\Scripts
- Open the moho document saved from Photoshop. Take out all of the images from the group and make sure no layers are in a group.
- Under menu scripts activate "Rename Layer (small)" This will change the (large) in layer names to (small).
- In file>Project Settings make your render size small.
- Export a psd file like before.
- Open the psd file in Photoshop and save another moho file.
- You will find a folder is exported with your moho file. This folder contains cropped versions of all of your images. Cut all of the small images out of this folder and paste them into the folder created with the large versions. Delete the moho file created from the small psd document.
- When you open the moho file created from the large images, go to menu scripts and activate "Decrease Image Resolution". All of your images will drop in resolution and be easier to animate.
-When ready to render, go to menu scripts and active "Increase image resolution". All of your images will become very high resolution!
DOWNLOAD: https://drive.google.com/open?id=0Bwzk- ... WZ3TDBRMmM
My method:
Wow, it turns out that it's pretty easy to write code for Photoshop. I created two photoshop scripts that will rename the (large) in names to (small) and another to do the reverse. They work really well and make it so you don't have to go back and forth or mess around with a whole lot of renaming.
Just download the script and put it in your photoshop scripts folder.
DOWNLOAD: https://drive.google.com/open?id=0Bwzk- ... 2psM0NyejQ
VB is pretty easy, but alas, I've never gotten around to really learning Javascript yet.
LOL!)) Let me rephrase that as "Wow, Photoshop scripting API is in four languages, and well documented!". I have done some Photoshop scripting before, and I really understand your "wow" here.dkwroot wrote:Wow, it turns out that it's pretty easy to write code for Photoshop.
Unfortunately, many other companies just cannot afford their scripting API to be that flexible and documented that well.
That's code in more ways than one...Stan wrote:...Unfortunately, many other companies just cannot afford their scripting API to be that flexible and documented that well.
I wondering if there is a way to use the 2d mesh with the size change? So the mesh could get smaller and bigger also.
Dale
Dale
dkwroot,
Do you have a EULA associated with your scripts?
My opinions and comments do not represent those of my employer.
http://www.ernestpchan.com
All I ask is that no one try to sell the code or anything like that. You can use them in your personal or commercial projects without any royalties.ernpchan wrote:dkwroot,
That's great but do you have an actual EULA that can be downloaded and read. For those of us in a studio/corporate setting, this is a requirement.
No, I don't have anything like that.ernpchan wrote:That's great but do you have an actual EULA that can be downloaded and read. For those of us in a studio/corporate setting, this is a requirement.
- TheMinahBird
Please tell me someone has this script and could possibly reshare it?
"Now hatred is by far the longest pleasure; men love in haste but they detest at leisure" - Lord Byron
Here's my own version that does the same thing, kinda.TheMinahBird wrote: ↑Wed Nov 15, 2023 7:52 am Please tell me someone has this script and could possibly reshare it?![]()
I'm not sure if it's in a working state and how to exactly use it, it's old and haven't used it in a long time. So you might need to dig around in the code and fix some stuff to make it work for your situation.
It might only work correctly with 1920*1080 moho files (and all might need to be imported while the moho doc is at that resolution - weird Moho quirk), as that's what we use.
If I remember correctly need to have your image next to each other in their respective folders like this:
- my_image.png (HQ image)
- my_image_LQ25.png (25% resolution of original file)
-- Provide Moho with the name of this script object
ScriptName = "LK_ToggleImageQuality"
LK_ToggleImageQuality = {}
function LK_ToggleImageQuality:Name()
return "Toggle Image Quality LQ/HQ"
end
function LK_ToggleImageQuality:Version()
return "0.1"
end
function LK_ToggleImageQuality:Description()
end
function LK_ToggleImageQuality:Creator()
return "Lukas Krepel, Frame Order"
end
function LK_ToggleImageQuality:UILabel()
end
function LK_ToggleImageQuality:ColorizeIcon()
return true
end
-- Recurring values
LK_ToggleImageQuality.layersDone = {}
LK_ToggleImageQuality.HQwidth = 1920
LK_ToggleImageQuality.HQheight = 1080
LK_ToggleImageQuality.HQtoLQ = true
-- LK_ToggleImageQuality.percentages = { "01", "02", "03", "04", "05", "10", "25" }
LK_ToggleImageQuality.percentage = "25"
LK_ToggleImageQuality.LQscale = 1/4
-- The guts of this script
function LK_ToggleImageQuality:IsEnabled(moho)
return true
end
function LK_ToggleImageQuality:IsRelevant(moho)
if MohoMode ~= nil then
return MohoMode.experimental
else
return true
end
end
function LK_ToggleImageQuality:Run(moho)
moho.document:SetDirty()
moho.document:PrepUndo(moho.layer)
local messages = { "i" }
-- * Remember doc resolution:
local docHeight = moho.document:Height()
local docWidth = moho.document:Width()
local layers = FO_Utilities:AllLayers(moho)
if self.HQtoLQ then
-- ** LOW QUALITY **
table.insert(messages, "LOW QUALITY")
for i = 1, 99 do--#self.percentages do
self.percentage = tostring(i)
if string.len(self.percentage) == 1 then
self.percentage = "0"..self.percentage
end
self.LQscale = i/100 --tonumber(self.percentage)/100
-- * Scale doc resolution:
moho.document:SetShape(self.HQwidth * self.LQscale, self.HQheight * self.LQscale)
self.layersDone = {}
for i = 1, #layers do
local layer = layers[i]
if (layer:LayerType() == MOHO.LT_IMAGE) then
self:ChangeQuality(moho, layer, self.HQtoLQ)
end
end
for i = 1, #self.layersDone do
local layer = self.layersDone[i]
table.delete(layers, layer)
end
if #self.layersDone > 0 then
msg = "- Scaled "..#self.layersDone.." images to "..tonumber(self.percentage).."% resolution."
table.insert(messages, msg)
end
-- * Reset doc resolution:
moho.document:SetShape(docWidth, docHeight)
end
else
-- ** HIGH QUALITY **
table.insert(messages, "HIGH QUALITY")
moho.document:SetShape(self.HQwidth, self.HQheight)
end
end
msg = "- Scaled "..#self.layersDone.." images to 100% resolution."
end
end
self.HQtoLQ = not self.HQtoLQ
moho:UpdateUI()
if #messages == 2 then
table.insert(messages, "- No images were changed.")
end
FO_Utilities:Alert(messages)
end
-- Changing the path on an image layer
function LK_ToggleImageQuality:ChangeQuality(moho, layer, LQ)
local imageLayer = moho:LayerAsImage(layer)
local imagePath = imageLayer:SourceImage()
if LQ then
if string.match(imagePath, "_LQ") then
return false
end
imagePath = string.gsub(imagePath,"%.","_LQ"..self.percentage..".")
else
imagePath = string.gsub(imagePath,"_LQ%d%d","")
end
-- * Check if path has changed:
if (imagePath == imageLayer:SourceImage()) then
return false
end
-- * Check if file exists:
if not FO_Utilities:FileExists(moho, imagePath) then
Debug:Log("Unable to locate image file for layer ["..layer:Name().."] File doesn't exist: ["..imagePath.."]")
return false
end
imageLayer:SetSourceImage(imagePath)
table.insert(self.layersDone, layer)
return true
end
