Image layer: Warp
Image layer: Warp
OK, I've never touched scripting so far, but it seems that I need some now.
Is it possible to script the "warp with bones" property? I've found no mention of this in the online documentation.
What I need is a script which I run after importing a bunch of images which sets all of them to "don't warp" - go through all layers, if image layer, set "warp with bones" to No.
I work with version 11, 9.5 and 8 - does the script need to be version-specific?
(Ideally this should go into the preferences - set warp yes/no for all images imported in the future.)
Re: Image layer: Warp
If you worked in 12 this would be easy. Just filter the layers by kind, shift-select all, and change all at once.
How much scripting do you really want to learn? I mean someone could just give you the code, but since you use older versions, maybe you want to learn enough to automate simple tasks like this. Kind of like writing macros.
neeters_guy
Post by neeters_guy »
This is a hack, but since ver. 8 (and 9?) format is text editable, you could do a search for "parent_bone -3" and replace it with "parent_bone -1". (I don't know what the numbers mean. I discovered this by doing a text compare with a simple anme file consisting of one bone and one image.)
Yes, for the old versions I rely on Text Edit too. So there's no solution for v11?
Thx so far.
This will work in v11 for all selected layers.
	local sel = moho.document:CountSelectedLayers()-1
	for i=0, sel do
		local layer = moho.document:GetSelectedLayer(i)
		if (layer:LayerType() == MOHO.LT_IMAGE) then
			layer:SetLayerParentBone(-1)
		end
	end
Should work in any version that allows multiple layer selection.
Thank you so much. I'll try that first in January!
